Cooking Gear Lube >
Cooking Gear Lube
Cooking Gear Lube
Old 05-24-2010 | 10:16 AM
DMAX's Avatar
Question Cooking Gear Lube
O.K. this is what I got.. Drive oil was backing up into my res. bottle so I tried the easy fixes first ,swapped the caps , had the shifter cable readjusted, had the drive itself inspected. Still cooking the lube. So W.T.F. I swap drives starboard to port port to starboard The drive is fine on the oppisite side but the bottle is still filling up on the starboard side.. Now what ? Thanks John
DMAX is offline
Old 05-24-2010 | 10:17 AM
DMAX's Avatar
These are Bravo 1's
DMAX is offline
Old 05-24-2010 | 11:32 AM
ballon78's Avatar
These are Bravo 1's
Do you have drive showers? One runs opposite direction and sometime run hotter. You may need drive showers!!!
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 05-24-2010 | 12:30 PM
DMAX's Avatar
Thanks for the reply, Yes I do have showers.
DMAX is offline
