Inverter ground >
Inverter ground
Inverter ground
Old 05-26-2010 | 09:07 PM
BDiggity's Avatar
Default Inverter ground
My inverter has a chassis ground stud in addition to the normal battery + & - connections. Should i run this ground to the engine block, or can i just run it to the battery too? When i was doing my wire testing, it was working fine w/out it, but i figured i better connect it to be on the safe side.
BDiggity is offline
Old 05-26-2010 | 09:59 PM
Ted G's Avatar
It should be connected to the chassis ground on the shore power panel.
www.cbpba.com
Ted G is offline
Old 05-27-2010 | 09:17 AM
BDiggity's Avatar
My panel is grounded to a main bus bar that other things are connected to. This i am sure goes back to a block. so i will just run it directly to the engine.
BDiggity is offline
