500 efi alternator? >
500 efi alternator?
500 efi alternator?
Old 06-02-2010 | 10:04 PM
Default 500 efi alternator?
My alt is not charging on one engine. I'm looking into rebuilding it but I'm confused on the part #. its a delco 12 volt 50 amp # 19020703 875285.
the #'s comes up as a 2.5 merc outboard alt and also comes up as a 575 sci merc????I have an 02 engine going by the serial #.I am going to check the other engine tomorrow for the alt #. Is it poss that merc used the same alts in different engines,I/O's and O/B's????? What do you guys reconmend,rebuild or replace? if replace do you go with an aftermarket brand alt? thanks
tcuda499 is offline
Old 06-03-2010 | 09:05 AM
DesertRage's Avatar
If you decide to replace it (I would) check out DB Electric. They have great prices and also offer high output replacements. I've got their 140amp 1 wire on mine.
Good Luck,
Jon
DesertRage is offline
Old 06-03-2010 | 09:21 AM
you should be able to walk up the street to any alternator shop and have them fix that cheap. short of all the marine bs , all the internals are off the shelf generic.
stevesxm is offline
Old 06-03-2010 | 01:46 PM
Yes, they did use the same alternater on more than one motor. You will have everyone tell you about all these alternators that are bigger and better but they will not fit. Go to db electrical and order one and be done with it.
29scarab10 is offline
Old 06-03-2010 | 08:24 PM
ballon78's Avatar
DB is the way to go!!
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 06-03-2010 | 08:29 PM
thanks everyone. looks like DB is the way to go. their alt is $111. cant beat that!!
tcuda499 is offline
Old 06-03-2010 | 11:34 PM
+1 on DB got mule starter for less than $100 oem over $500 n seadoo starter for less than $100. I didn't even price oem.
shark42 is offline
Old 06-04-2010 | 07:10 AM
at 111 bucks you can't go wrong... but i would still have the old one fixed and have it next to the spare props on board.
stevesxm is offline
