holey carb gurus
The 2 screws that go in to the metering block on the front are the idle mix screws. The one screw that acts as a throttle stop is the idle screw. No such thing as air bleed screws.
Like mrfixx and I said, start at one turn out on the mix screws and go in (cw) evenly with both until the problem resolves.
Rick, I run the idle screws in a little at a time with the boat in gear idling until the motor dies. Then back out 1/8 or 1/4 turn on each idle screw. Needs a lot of warmup to idle but doesn't load up.
Long time cult member.
Man, r any of u guys coming to Bermuda soon..I had the same problem last season..I recently sent the carb back to be recalibrated..haven't sea trailed yet to see if it's any better..but will keep u guys updated..n i only have 12hrs on this motor..
rssteiny.. i feel your pain..mines does the same thing..idles fine.. around 950rpms, but once in gear and under load it drops instantly to around 650rpms and stumbles n wants to cut out unless i come up on the throttles..i ready to sacrifice speed for a dock friendly boat..good luck.but if u have any findings please advise..
Q
Q
You may just want to buy an upgraded carb from holley with 4 corner idle circuit since you have gone to the steeper cam to help the engine out.
I have a set of 2 year old bg demonds 875s maybe i should try them just need to do some different plumbing. Im going to play with the holleys this weekend on the water see what happens first ill let you all know.
I run Bob Madara's cams that are ~228 I, 232 E duration with ~.598 lift on both I & E, pretty mild idle but they pack the charge in really well on the top end. Peak hp is at 5500 rpm. I am still in the 90-91 mph range but looking to do another project with Bob this year to take it up another notch.
