Idle adjustment >
Idle adjustment
Idle adjustment
Old 06-07-2010 | 10:37 PM
BDiggity's Avatar
Default Idle adjustment
Started my engines last 2 weekends & both are idling about 1000rpm. so i need to adjust them down some. looking at the holley dom 1050 doc, it says to adjust both the primary & secondary screws
"This adjustment should be made to both the primary and secondary screws in equal amounts, so that the throttle plates are opened the same amount."
do i adjust them simultaneously or adjust the primary to where it needs to be, then move the secondary the same amount?
also what should the idle be for my hawk 525's? 600 rpm or so?
BDiggity is offline
Old 06-08-2010 | 09:09 AM
Count the number of turns it takes to close both throtle plates and divide that by 2. Now open both sides the same. Then for your final adj. do both sides the same.
fbc25el is offline
Old 06-08-2010 | 08:50 PM
Just adjust the single main idle speed screw first. Set the neutral idle to around 850rpm. You really need to play with the idle air bleed screws while in the water so you can put the engine under a load by putting it gear.
Griff is offline
