Cmi Etops
Cmi Etops
Just recently installed CMI ETOPS on a 496 MAG HO. While in neutral exhaust water only comes out the starboard exhuast. I'm told by "others" that this is normal while in neutral. Can't get CMI to answer my emails. Would really appreciate any insight. Thanks!
i installed a set on a customer's 277 islander and at idle in neutral i had good water flow through both pipes, definatly check the impeller also check to make sure the collecter tube hoses aren"t pinched off.
port side fit ok starboard on the other hand was a nightmare due to the cool fuel module being in the way
i had this problem while installing them ,had to make my own, so much for a bolt on kit!
