525 sc Thermostat >
525 sc Thermostat
525 sc Thermostat
Old 06-09-2010 | 09:16 PM
Default 525 sc Thermostat
Just finished my 525 project today fired for the first time , ran good just curious i put a 160 thermostat in it , but what did the 525s come with or what should be put in?
stingray698 is offline
Old 06-09-2010 | 10:20 PM
FActory spec book says 143 deg. Mine run 140 & 150 respectively so I'm sure that's what's in them.
paulb32 is offline
Old 06-10-2010 | 09:35 PM
They had a 140* tstat from the factory.
Griff is offline
Old 02-13-2012 | 08:55 AM
Griff would you have the part # for the 140 Degree thermostats? Also were would you recomend buying them? Thanks in advance
kgreskow is offline
Old 02-13-2012 | 02:56 PM
Any Merc dealer. The same one is used for all carbed Merc BBC engines. Make sure to use the factory gasket with NO sealer or your temp gauges will not work.
Griff is offline
Old 02-13-2012 | 03:16 PM
Griff your the man thanks for the tip.
kgreskow is offline
Old 02-13-2012 | 07:59 PM
What would you recommend for spark plugs in these engines?
JD33 is offline
Old 02-14-2012 | 01:50 AM
I ran NGK UR5's( NGK stock #2771) in my 525SC stock and after bumping it up a little. They are the same heat range as the stock AC R41T's, but have a slightly extended tip to help the engine idle better and keep them fouling.
Griff is offline
