Air Gap Intake Manifold >
Old 06-17-2010 | 08:25 AM
35fountain's Avatar
Question Air Gap Intake Manifold
Just intalled 2 air gap intakes, and the large water hose from the thermostat housing to the water circulating pump is short about 1 inch. I got it on but it seems to flatten out the lower bend of the hose.. Inside diameter of that water hose is 1 3/4 ". In between standard pipe sizes. Has anyone else used these manifolds. Any ideas ??
35fountain is offline
Old 06-17-2010 | 08:48 AM
Go to home depot or any other hardware store and look in the plumbing section and they should large hose barb conectors. Then cut your hose and install the conector till the hose is long enough.
fbc25el is offline
Old 06-17-2010 | 09:21 AM
Knot 4 Me's Avatar
You'll find that the hose from the 525SC will fit perfectly.
Knot 4 Me is offline
Old 06-17-2010 | 12:10 PM
35fountain's Avatar
Thanks...
Old 06-17-2010 | 12:23 PM
Knot 4 Me's Avatar
This was changing from the standard truck intakes on 330 HP 454's to Edlebrock Air Gaps with 4150's. 525 SC hose fit perfectly.
Old 06-18-2010 | 07:12 AM
35fountain's Avatar
Went to a plumbing supply ..I got a 2" brass hose barb.. Cut the hose ..added some WD 40.. went right on.. back in business.. 15.00 each
Thanks for all your help.. I will consider the 525 sc hose...
Old 06-18-2010 | 07:24 AM
Knot 4 Me's Avatar
Good call on the barbed fitting. I've seen some use smooth plastic tubing and the clamps will not hold and eventually the hose comes off. Washes the engine compartment down quite nicely!
Old 06-18-2010 | 02:38 PM
35fountain's Avatar
Worse than that ...plastic pipe?? .. What happens to it incase of a overheating situation..I would think a 175 degrees would be max
Old 03-04-2011 | 11:22 AM
I love this forum! I just made this same upgrade and ran into the same problem. Hop right on OSS and with a quick search 2 mins later I had my answer. Thanks guys
Hammered is offline
