J.c. Marine,,,496 Impeller Kit
can you still order there 496 raw water pump kits,,,are they still in business
Did you ever found the info? Are they still in buisness? I need a good 496 pump rebuild kit. Thanks
FWIW, I installed a aftermarket marine 496 rebuild kit in mine this spring. Nice kit and impeller. Impeller had same rubber consistency as a oem Merc going by feel. No problems after one season. Visibly more water out the tips vs 3yr old Merc impeller.
Thanks where did you get it?
Originally Posted by JS232
(Post 4484207)
Did you have to machine the pump bracket? Or plug and play? Does it use a standard merc impeller?
I would not advise using a 3 year impeller for any boat app. Even with zero time on it. They form a set while sitting. The impeller for the AM kit is shaved down a bit. Apples to apples it produces a bit of less water volume flow than new merc impellers with a good condition housing.
Also the kit does not remy any side wear nor any side scaring in the impeller housing. It is not uncommon to have side wear and or side scoring in these brass impeller housings especially boats without sea strainers. Also improper winterizations with water that freezes in the impeller housing can check them up internally. You can volume test for water output right after the impeller to make sure its within OEM spec. |
Bup, Any other known options? My housing has the scoring on both sides. Maybe i should just have the thing machined with brass...
(Post 4484627)
Originally Posted by Ryan00TJ
(Post 4484637)
Hardin Marine has a nice stainless gen 7 kit. From what I've heard it worth every penny.
| All times are GMT -5. The time now is 08:52 PM. |
