oil sandwich adapter >
Old 06-19-2010 | 08:23 PM
Default oil sandwich adapter
So i put a earls thermostatic sandwich adapter on my BBC gen 5. I believe part # 503. It appears to be leaking from inbetween the stock filter location on the block and the sandwich adapter. Has anybody ever had a problem with this unit leaking from where it seals to the block? Any help would be great
conquest30' is offline
Old 06-20-2010 | 09:30 AM
I have had the same problem on a Gen V also. It kept leaking around the o-ring seal. I did everything to it and never did get it to quit. I went back to the factory adapter.
Sweet Nmocean is offline
Old 06-20-2010 | 09:55 AM
I have a Mocal sandwich oil T-stat. Prior to installation I examined the sealing O-ring and did not like its diameter. Searched at McMaster Carr and got an O-ring that was slightly larger and installed it in place of. Never had a leak in 4 years.
BadDog is offline
Old 06-20-2010 | 06:46 PM
hey sweet was your a earls? anybody else have a problem and a possible fix? thanks
Old 06-22-2010 | 11:22 PM
nobody has had this problem before?
Old 06-23-2010 | 10:17 AM
Not many are using the sandwich adapters. I believe the sealing arrangement is different on the oil T-stat version. I don't know if mine would have leaked, I just changed the O-ring because I could.
BadDog is offline
