pwr strng pump
I repowered my boat with VP 420 DPX engines. They both have power strng pumps. Is there a way to rig both pumps into the steering system so that either engine will power it? If not, what do I do with the extra pump? Feed the HP line directly into the return on the pump? Any suggestions would be appreciated.
can't run both pumps to steering, can you remove p/s belt ?
No, its a serpentine belt.
buy a fitting to connect the 2 lines together and your all done.
OK, so you're saying run the high pressure line from the pump directly to the return port on the pump?
| All times are GMT -5. The time now is 11:36 AM. |
