Timing on a supercharged small block >
Old 07-18-2010 | 07:51 PM
Ditto on all the advice already posted.
Way too much carb and not enough boost.
Griff is offline
Old 07-19-2010 | 06:00 AM
I second that....also locking the dist to no advance and running 28-30 will work well...
ezstriper is offline
Old 07-19-2010 | 10:08 AM
Timing is very dependant on the build. Compression ratio, cam, cylinder head design, etc.. Are they fast burn heads? 3 lbs of boost is not much. RPM also depends on the build. If it's a stock cast rotating assembly 4600 is not too far out of line. 30 degrees total is a decent starting point. I wouldn't run more than that unless you have all this information.
Bob
Full Throttle Marine
bobl is offline
