purchacing dry exhaust >
Old 07-07-2010 | 07:54 AM
i also have a trs setup< nice
mookster is offline
Old 07-07-2010 | 11:07 AM
I'm looking to buy the Lightning reduced water's this winter. Anyone have any experience with these?
http://www.cpperformance.com/p-11813...r-headers.aspx
ittledoo is offline
Old 07-26-2010 | 09:18 AM
Anyone have any input on the reduced water headers? Thx
ittledoo is offline
Old 07-26-2010 | 09:55 AM
Brad Zastrow's Avatar
Why do you want dry exhaust? It is crazy loud. I run wet tails on my 1450 hp engines with no issues. CMI has dry exhaust if you really want it. Not advised for the noise issues though.
Call Ateco for a quote.
Brad Zastrow is offline
Old 07-26-2010 | 01:50 PM
Eh, they're not that loud. My CMI's are dry to the tips.
Granted I'm not pushing 1450hp, but with a big cam 598ci, it still makes some noise.
Philm is offline
Old 08-09-2010 | 10:28 AM
I really don't want dry, but CPP said that I pretty much need it for the cam.
comp roller
lift .613 .608
@ .050 230 236
lobe separation 114.0
Your opinion?
ittledoo is offline
Old 08-09-2010 | 10:49 AM
comp roller
lift .613 .608
@ .050 230 236
Your opinion?
i think that cam will work just fine for a wet tail setup.
mike tkach is offline
Old 08-10-2010 | 07:58 PM
rlj676's Avatar
I have something similar to reduced water pipes. I have the standard HP500 Gil manifolds with high rise pipes that are mostly dry. There is a dump about 2 feet from the tail that drains a bunch of water out a hose, and then another 1 inch dump at the end that clears what is left in the jackets. I believe there is then a little mixed into the exhaust....but not much. My 500 was LOUD. I just put in some slip-in mufflers to be a little more sociable on board actually.
rlj676 is offline
