Drive Oil Analysis Lab >
Old 07-06-2010 | 01:06 PM
Rage's Avatar
Default Drive Oil Analysis Lab
What oil analysis labs out there might have done more testing on drive gear lube than the rest. I have already contacted Blackstone Labs and they do not have much. I plan on starting drive gear lube analysis to track drive gear wear versus the lube oils I try and I want a lab that has a bigger data base on drive lube oil as a reference.
If anyone has personal drive lube analysis history that they would not mind sharing that would be appreciated as well.
Bravo XR is the drive of primary interest.
Rage is offline
Old 07-06-2010 | 03:08 PM
I use Oil Analysis Lab in Spokane, Washington. I have a report from my Bravo X drives with about 60 hours on the oil, which was still good to go. I was using the AMSOIL Marine 75w/80w-90 Gear Oil, but am now using the AMSOIL 75w-110 this year.
07DominatorSS is offline
Old 07-06-2010 | 03:54 PM
Try a caterpillar dealer. they have analysis labs on site and they do all different lubes.( gear ,engine, antifreeze) I use them for my ocean yacht on a regular basis to keep track my engines in my big boat.
Allicat38 is offline
Old 07-06-2010 | 04:21 PM
Rage's Avatar
Could you share the PPM if iron number that was reported and your engines horsepower?
Rage is offline
Old 07-06-2010 | 04:23 PM
Rage's Avatar
I really need someone that has a history of testing Bravo drives. Thanks.
Rage is offline
Old 07-07-2010 | 10:34 PM
Rage's Avatar
ttt
Rage is offline
