Ignition timing retards >
Old 07-13-2010 | 02:03 PM
Exclamation Ignition timing retards
why does my ignition timing retard from 10 degrees to 0 when i rev the engine to appprox 2000 rpm,i have tried 3 different ignition modules and 2 distrbutors , it is a carburated 502 Mercruiser
markku4444 is offline
Old 07-13-2010 | 02:12 PM
If it's a thunderbolt V ignition, they have ignition retard function built in. It is controlled by the knock deterctor system. If that malfunctions or the connections between it and the ignition module are loose, it will pull timing.
Putting a thunderbolt V module on a IV system will cause the same thing.
apollard is offline
Old 07-13-2010 | 02:48 PM
I dont think my engine got a knock detector,i have a thunderbolt IV, can i use a thunderbolt V if the engine does not have the knock sensor?
Old 07-13-2010 | 03:25 PM
No, they are not interchangeable, the V will retard all the time w/o the knock module present.
apollard is offline
Old 07-13-2010 | 04:08 PM
Ok thanks i will try a complete MSD system and hope that will work
Old 07-14-2010 | 08:34 AM
put a HEI in it, run no vacume advance, set your total timing, simple works great...
ezstriper is offline
