Interior cleaning >
Interior cleaning
Interior cleaning
Old 07-13-2010 | 09:17 PM
Default Interior cleaning
Looking for the best way to clean up the interior of a boat I just bought. Looks like it has a little mold on the vinyl. The interior is white mostly. The boat is a baja 30'. Thanks guys.......
drunkstang is offline
Old 07-13-2010 | 10:20 PM
Do a search. This has been discussed many times. Lots of opinions.
Revd Up is offline
Old 07-13-2010 | 11:38 PM
Simple green and a Magic Eraser. Lightly scrub as if you were polishing the vinyl. Then sponge off with warm water. Finish up with your favorite protect ant and you will be amazed.
Darrell.
DMOORE is offline
Old 07-13-2010 | 11:58 PM
Thumbs up
First time i tried Magic Eraser I couldn`t believe my eyes and kicked myself for not trying it sooner..
ended up doing the whole interior while the wife went and got more boxes of Magic Eraser.. its an amazing difference!!
ICDEDPPL is offline
Old 07-14-2010 | 03:15 AM
I use a magic eraser soaked with a mild degreaser and it works great every time. Works great for the floor of the boat too!!!
JasonKelowna is offline
Old 07-14-2010 | 06:51 PM
magic eraser great cheap product
firehawkcat is offline
Old 07-14-2010 | 08:48 PM
Thanks guys, ill pick some up tommorow and try it out. Ill let you know how it worked.
Old 07-14-2010 | 10:17 PM
Someone had once mentioned that scrubbing with a magic eraser may be abrasive enough to remove a "UV" coating from vinyl. I'm not very knowledgeble regarding the composition or makeup of vinyl, but is there indeed a UV blocking layer on most marine vinyl or is this just BS? I'd hate to go over my interior only to have it come apart in a year.
Jpzaluski is offline
Old 07-15-2010 | 09:17 AM
The UV properties of plastics (including vinyl) are chemicals added to the product during production (ie, mixed in) rather than a coating on top. You can apply more as a coating, but that's going to wear off anyway.
apollard is offline
Old 07-15-2010 | 09:32 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
for deep in dirt I use LAVA soap with simple green or for general cleaning I use magic eraser
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
