Major Motor Problems >
Old 07-16-2010 | 04:03 PM
Originally Posted by FIRST AFENCE
give the boat to me then you won't have any more problems.
LOL gee thanks.... guess thats end of this summer
fountain07 is offline
Old 07-18-2010 | 07:53 AM
well bad news there is in fact a issue with exhaust and how fountain shortened it which in turn was the cause of the motor injesting water . SOL
Old 07-18-2010 | 08:31 AM
Wow that sucks .
FIRST AFENCE is offline
Old 07-18-2010 | 08:01 PM
Wow that sucks .
your telling me. What confuses me is even if reggie shorten exhaust pipes what affect would that have on water in oil I dont get it. Unless there was a crack or head gasket failure .
Old 07-18-2010 | 09:08 PM
It was most likely reversion it is when water from the exhaust is sucked back into the motor. Do a search on here there is alot of info about it especially on the 525 merc.
Old 07-20-2010 | 01:35 PM
thanks First Afence I looked that up and that is indeed what it is. Dropping it off tom for repair hopefully the summer isn't shot
Old 07-20-2010 | 03:16 PM
Glad i was of some help . Hope they get you up and runinng soon:
Old 07-21-2010 | 12:27 PM
Likely has CMI headers? They suck! You can have them tested and welded if they are not too bad. I have them on my Donzi and have replaced 3 so far. Have a motor with only 160lbs comp. on the port bank due to that. Im going to rebuild that one in the winter. Good luck!
THE OUTLAW is offline
Old 07-21-2010 | 12:46 PM
Put some rubber FLAPS on the end of the tail pipes. If you have a large wave hit the back of your boat and you don't have rubber flaps that will close on water impact, the water can travel up your pipes and into your cylinders. This can easily happen if your engines are turned off and the water is ruff. Once you have water in your cylinders and you try to start the motors, BOOOM!! I use the clamp ons. It's a cheap investment.
UrbanDisturbance is offline
