Shoot Through Depth Sounder >
Old 05-02-2002 | 03:39 PM
shoot throught type depth finders.....the installation depends a great deal on what the hull is made of. And depending where in the hull it's mounted. On my cat that has great deal of kevlar and core (of some sort) I forget. Eliminator knows. I had to frill a 3/4 " deep hole before I could get a reading, then it works up to on plane...because then there is too much turbulance for it to read. After your on plane...doesn't matter much what the depth is....I guess. Cause you ain't stopping in time anyways. Mine is a Teleflex...
enticer is offline
Old 05-02-2002 | 03:51 PM
Airmar is the transducer manufacturer that supplies many companies.
Interceptor is offline
Old 05-02-2002 | 04:05 PM
Thanks everybody for the advice so far. Now can any body tell me if my 1985 28cig ss has coring in the hull, or has any specific advice for installing the unit on this particular boat?
THRILLSEEKER is offline
Old 05-02-2002 | 05:03 PM
Dredgeking's Avatar
i need to re epoxy mine. it came loose a while ago. any suggestions for epoxy?
Dredgeking is offline
Old 05-02-2002 | 05:06 PM
laster's Avatar
Cigarette should be able to tell you if your boat is cored. If you have the depth finder, and want to test it before doing anything permanent, it is not too difficult. You need to have the boat in the water - at least 6 - 8 feet deep as some depthfinders lock in at shallower depths. Put the transducer in a baggie full of water and put a twist tie at the top. Set the baggie in the bilge in a likely location with the transducer pointed down. Run temporary power to the depth finder and see if you get a reading. Try different locations to see if it works better or worse and to try to find one which both works and will be accessible to make a permanent mount. If you can not get a reading in this manner then you most likely do have a cored hull. Good luck.
laster is offline
Old 05-02-2002 | 05:28 PM
29Fever
DK,
I just did mine a couple of weeks ago. I used 2 part JB weld (any hardware store) Make sure to sand down the old epoxy and try not to have any bubbles in the new mix. I got my info from Fever Mike and it seems to be holding up pretty well so far.
Old 05-02-2002 | 05:40 PM
Dredgeking's Avatar
thanks 29. I bet some 2 ton epoxy will do the job also.
Old 05-03-2002 | 08:58 AM
MrCIG's Avatar
Charter Member#330
Thrillseeker,
I have a 85 38' Cig and it is not cored. Solid fiberglass about 3/4" thick. I don't think Cigarette cored until recently.
Mark
MrCIG is offline
SteveB
2
10-03-2007 10:09 AM
Pismo10
03-31-2006 12:24 PM
completelymobile
05-15-2004 05:43 PM
Raging Bull
Fountain
6
06-03-2003 02:23 PM
Sydwayz
05-06-2002 06:47 PM
