What are these wires for? >
Old 05-01-2002 | 08:32 PM
Waterfoul's Avatar
Gone Fishin'
Default What are these wires for?
On the inside of the transom (engine compartment) of my bravo drive, there are two thin wires that come out, one orange, one black. What do they do? What are they for? They come out where the trim hoses come out, way at the bottom of the transom assembly. I know they are not the wires for the "hockey puck" trim indicators. They are a dual wire, and all black.
Any help appreciated.
Mike
Waterfoul is offline
Old 05-01-2002 | 08:34 PM
Mbam's Avatar
Offshoreonly Advertiser
Those are for the mercathode system (helps prevent corrosion)
Mbam is offline
Old 05-01-2002 | 08:42 PM
Waterfoul's Avatar
Gone Fishin'
Oh REALLY!! Maybe I should hook those up since the ugly thing is still on my motor. Or, can I remove the mercathode since I never leave my boat in the water (always fresh water by the way) more than a few days at a time???
Old 05-01-2002 | 09:46 PM
Official OSO boat whore
I'm leaving mine off for the same reason. You really can't remove the wires, because they are attached to the thingy on the bottom of the gimble that looks like a epoxy freighter. If you remove the freighter gizmo you'll end up with a leak due to a hole that it formerly covered. Either loop the wires and tie them off, cut them off, or make up a cover plate for the hole.
BTW-we should be certain that we are not talking about your trim indicator/limit switch wires.
Cord is offline
Old 05-02-2002 | 08:09 AM
cougarman's Avatar
Default WaterFoul
You can remove the whole thing if you want. It's only two
nut's with fixed stud's. On our old boat we made plates
to cover the holes on both drive's with a good gasket material.
Just one more thing to clean up and get out of the way.
If I remember correctly it just has a small O-ring there now.
Cougarman
cougarman is offline
Old 05-02-2002 | 08:27 AM
Budman's Avatar
From: Kentucky - where the women are so fast we have to put a governor on 'em!!
I think Merc makes a zinc or a plate that bolts on in its place. My Alpha had the Mercathode, and the Bravo transom assembly that I replaced it with had what appeared to be a zinc in its place. You will also have a Mercathode module mounted on your motor close to where the starter solenoid is located. You might want to disconnect the power lead to this as well.
Budman is offline
Old 05-02-2002 | 08:45 AM
formula31's Avatar
Anybody who wants to unload one or two of those mercathode assemblies, let me know. I need them for my tank that stays in the water. Thanks
Tom
formula31 is offline
Old 05-02-2002 | 08:59 AM
I have one. Any ideas what it's worth?
[email protected]
Cord is offline
Old 05-02-2002 | 09:19 AM
KAAMA's Avatar
Cougarman, could you do me a favor and get a hold of "Johnny Bravo" for me....he's got a Cougar something like yours here in Michigan. Have him call me at 616-291-7932 Thanks, Mark (KAAMA)
KAAMA is offline
Old 05-02-2002 | 10:44 AM
formula31's Avatar
$69 new. I could make you a block off plate if you need it.
