496ho Water Drain Actuator >
Old 07-18-2010 | 04:46 PM
Default 496ho Water Drain Actuator
My water drain winterization actuator assembly is leaking water on my 2003 496 ho. Its on a twin engine setup and, of course, it would be the port motor. Looks like one or both of the exhaust manifolds would have to be removed to access. I would like to permanently do away with this gizmo. If I replaced with a piece of pvc or brass nipple would this work and just disconnect the hoses to the shrader valve?
goldeneyee is offline
Old 07-18-2010 | 11:12 PM
crayolacrazy's Avatar
I did teague sells a stainless sleeve fit perfect
crayolacrazy is offline
Old 07-19-2010 | 09:42 AM
Thanks for the info. No problems in disconnecting the lines to the shrader valve?
Old 07-19-2010 | 10:14 AM
Just got off the phone with Teague and no one at their company seems to know anything about a stainless sleeve for this application. I was also cautioned that the whole water drain system would have to be decomissioned and plugged tp prevent water leakage problems.
Old 07-19-2010 | 08:30 PM
Barrydet's Avatar
Default 496
The air actuator assembly mounts on the rear of the raw water pump. A skilled Mercury mechanic can remove the water pump without removing the exhaust system components. I watched 'em do it on one of my twins. Here is the part number for the actuator assembly-863717A2.
Barrydet is offline
Old 07-19-2010 | 10:07 PM
Thumbs up I can Help
I have a fully functional, non-leaking drain system if you want it. 100 bucks to your door ups ground.
SDFever is offline
Old 07-20-2010 | 11:20 AM
SDFEVER: PM me with your contact info. If I can't find a suitable sleeve you are my first alternative. Thanks... Bill
