stuck in gear
took the 2covers off ball and spring perfect still has greas on it everthing looks good and clean prop will not turn by hand either way but if i fire the motor prop spins i will have a go a taking drive of is it just the six nuts i can see and rams or is there a lot more going on in there that i cant see ???? regards paul from england
Here is breakdown of what is there.
http://www.mercruiserparts.com/Show_...FXZ%2DDrive%29
When you shift you should see the Shift shaft move. Are you?
