shift lever question >
Like Tree0Likes
Old 07-26-2010, 01:53 PM
My Boat: 1971 Lyman Offshore 2004 Sea Ray 320 Sundancer
Default shift lever question
I've got morse shifters and throttles and i keep having an issue with my port shifter slipping back toward the neutral position( an 1inch or 2) while under way. The shifter never takes the drive out of gear but it annoys the sh!t out of me. Is there an adjustment to stop it from creeping back?
bsebesy is offline
Old 08-16-2010, 01:01 PM
My Boat: 2003 Advantage Victory 32
Same thing is happening with my Morse shifter, but it is the starboard throttle. Any ideas?
CrownHawg is offline
Old 08-16-2010, 07:22 PM
My Boat: 2000 firehawk 2600
check detent ball behind rear cover
firehawkcat is offline
Old 08-17-2010, 07:24 AM
After looking at the original post, my problem is not the shifter, but the throttle. The shifters are quite stiff and I would like to ease them up a bit. Is there adjustment for the throttles and the shifter? I took the whole shifter assembly out and see that it is actually one piece. Looks like ALOT of little parts to go flying if I try to disassemble it.
Old 08-17-2010, 09:48 AM
My Boat: '89 Baja, Force 320 '88 Baja, Force 370
Not too had to disassemble...do it on a clean bench after you remove from the boat/cables. If you have stiff throttles/shifters, you will probably need to replace the cables. These get stiff over time and there is no fix besides replacement. My buddy did this and I just got done doing it on my boat.
Rexx is offline
Old 08-17-2010, 09:49 AM
Had... Meant to say bad
Rexx is offline
OSO Sponsor
OSO Advertiser
OSO Advertiser
OSO Advertiser
