Stereo install >
Stereo install
Stereo install
Old 03-15-2011 | 05:16 PM
  #71
Fountain4402's Avatar
Originally Posted by capt2130
Yes you could do that. I just like my subs dedicated to one amp. But that's just me. It also depend how my sound your looking for.
well just got the boat and have to spend all the money getting it ready and some other toys for it. So basically looking for the best bang for my buck right now. Either way I want something that is nice and be heard but not from miles away either
Fountain4402 is offline
Old 03-15-2011 | 05:56 PM
  #72
Originally Posted by Fountain4402
what do you mean by full component set and cross over.
They are called components because they are a woofer (6 1/2", 7" etc) and the tweeter (1", 1 1/2"). The crossover filters the correct frequencies to the correct speaker and the two act as 1 channel, or 1 speaker. Its a better way to filter highs and mids than the normal speaker you see with a tweeter built in.
sleev-les is offline
Old 03-16-2011 | 07:44 AM
  #73
I have a question and maybe some help needed. I set up a few systems in the past and kind of know whats going on. Either way I got a 91 fountain with a tape deck in it and regular 4 speakers. My plan is obviously a cd player/MP3 head unit. For now I am going to stick to two subs and two tweeters maybe get 4 of them.
Questions are as follows.
1. I plan on getting two 10's or 12's whatever Looking at getting 500watt ones maybe 1000. Now Should Hook the tweeters into the head unit which is probably going to be a 4x50watt channels in it. Or should I get a 4 channel amp thats 1000 watts and run subs at half way and run the tweeters into the amp. Really just wondering what kind of amp I need. AlsoI have a Zune and plan on running that I dont want a head unit that you have to plug in the headphone jack into it and still find power for the zune. I want one that has a USB so I dont have to have two wires.
I just finished putting a new system in my boat. Its a 27 Fever so there isn't a lot of spare room. My experience level is about the same as yours so I kept it simple (KISS). I started with a Kenwood KTS-MP400MR Stereo + KTS-RC100MR Remote and connected it to an Alpine PDX-5M 5-Channel Class-D Marine Digital PDX Amplifier and it's pushing 2 10" Kickers on the mono channel and 4 Infinity KAPAs (2 6X9s and 2 6 1/2s) on the other 4 channels. I know the Infinity's aren't marine rated, but I expect them to be blown-out before the weather gets to them. I plan on replacing them with some Polks. I built a pod to mount the remote on the dash next to my compass since there's no room otherwise. And the sound...it's absolutely KICK_AZZ...way more than I ever expected and the subs aren't even broke-in...I admit the subs are low-end, but they'll do for now. This isn't a super-power system, but it works for me...I hope what ever you end up with does the same for you.
Thunderstruck27 is offline
Old 03-16-2011 | 08:27 AM
  #74
thanks what I am thinking is this. Right now there is speakers in the back seat there and two in the cabin. Im thinking about putting marine grade subs in back seat two speakers in cabin with regular stereo and amp in there since it will be out of the elements. Anybody see a flaw in this logic besides a 0 or 2 gauge power wire going to the battery will be expensive unless i can hook into the dash.
Old 03-16-2011 | 08:53 AM
  #75
It's your boat...if you want 2 speakers in the rear seat and 2 speakers/amp in the cabin...that makes perfect sense. Definitly run the 0 or 2 gauge back to the battery though and use the mult strand wire cause it's easier to bend and work with(car stereo shop is a source). I also put my amp in the cabin. I installed it just above the radio using the access cut-out just above the radio where the mirror was mounted. The PDX-5M was a perfect fit.
Old 03-16-2011 | 12:48 PM
  #76
Did some looking arond and is this what they consider a 2 way speaker? Also does this replace the need for subs or is it just a better option than a regular tweeter speaker.
Old 03-16-2011 | 01:16 PM
  #77
No, a 2 way speaker is a coaxial speaker (tweeter is built in, mounted to center of the woofer cone.
Here is an example of a component set
http://www.crutchfield.com/p_107DB65...mponent+System
Components are nice because they give a clearer mid bass and high range frequency. They don't eliminate the need or want for a sub though because you will never get that type of base out of a midrange speaker system. Components just give more clarity and frequency separation.
Old 03-16-2011 | 01:23 PM
  #78
got it now thanks for the help
