BBC tall deck-"decked" too many times >
Old 08-11-2010 | 01:19 PM
Default BBC tall deck-"decked" too many times
I've got a 427 Tall deck Chevy stroked out to a 482. After having some issues, the block was sent out to be decked and honed. The block comes back and the engine builder notices that the pistons will hit the heads. After looking into it further, he realizes the engine has been decked several times and the current set up won't work. My questions are: Are there shorter rods I can use? Or pistons that are shorter? All of the combinations he came up with won't work-they are all too long. Any suggestions?? Do I make it into a "de-stroked" engine? What do I do? Buy a new block??
Thanks!
Fast Shafts is offline
Old 08-11-2010 | 01:51 PM
You can get custom pistons with a shorter deck height, or another block.
SHAWN DAVIS is offline
Old 08-12-2010 | 07:13 AM
PatriYacht's Avatar
Thicker head gaskets are the easiest solution. How far out are the pistons?
PatriYacht is offline
Old 08-12-2010 | 07:48 AM
I would just run thicker head gaskets as well
ezstriper is offline
Old 08-12-2010 | 09:25 AM
PatriYacht's Avatar
Cometic will make them up to about .080 thick. You will need about .040 between the head and the piston so that's good for a lot of decking.
Old 08-12-2010 | 09:32 AM
Default Fixx
if all else fails i have a block,,Virgin!!
FIXX is offline
Old 08-12-2010 | 10:00 AM
mcollinstn's Avatar
I've seen em run sticking out of the block pretty far. It's not "optimal" but it works. Top edge of top ring ought to be at least .060 down from top of bore to keep from accelerated bellmouthing of the top of the cylinder.
mcollinstn is offline
Old 08-12-2010 | 10:52 AM
Thanks for the responses! I'm still weighing my options, but leaning towards a special order low "deck piston".
Old 08-12-2010 | 12:01 PM
Depending on the piston I've flycut the decks may have to flycut intake reliefs as well Are you using a 4 1/4 crank with 454 pistons?
rogersspeedshop is offline
Old 08-12-2010 | 02:11 PM
Gary, this is Bob here from 606 Lock'd Up-I didn't know if you knew my OSO name. Your shop actually did the machine work on the crank and the block-sent to you by Kurts Marine. Excuse my ignorance but what is a "fly cut"?
The block is a 427 tall deck, stroked out with a 4.25 crank and 4.25 pistons.
Thanks for your help and suggestions!
Bob
