454 over heating.................... >
Old 08-21-2010 | 02:12 PM
Default 454 over heating....................
i have a 98' 454 mercruiser and was experiencing over heating problems,after back flushing and realising my impeller took a crap on me after finding all cunks of it,, is there any easier way or "trick" to changing this thing out??????
sassea is offline
Old 08-21-2010 | 02:22 PM
Backflush again,making sure ALL the parts are out. When replacing the impeller, use some vasaline to help lubricate it on startup, and double check to make sure the impeller is set to spin the correct way. A buddy of mine set the impeller on his boat to spin the wrong way ( inserted it by twisting it the wrong way)it ate itself instantly.
Darell
DMOORE is offline
Old 08-22-2010 | 08:58 AM
I would pull the water hose at the ps cooler (if you have ps on that motor) or oil cooler. Typically you find all the impeller chunks in the first heat exchanger and you won't necessarily get the out by back flushing. Don't rev you motor past 2000 rpm on the hose or you will replacing the impeller again.
Rexx is offline
