Inward vs. Outward turning props? >
Old 08-31-2010 | 12:07 PM
Default Inward vs. Outward turning props?
2005 PowerQuest 300 Revenge 496 Mag Ho's. Props turn in and most other boats I see turn out, what's the difference, plus the top of my props are level with the bottom of the hull and most others are 4 to 6 inches deeper in the water than mine. The dealer said to keep the drives down and in all the time accept at high speed for the boat to run best. New performance boat owner so all opinions appreciated.
miwettig is offline
Old 08-31-2010 | 07:39 PM
RICHARD CUNY's Avatar
I am new to this also only 4 years now but I would recomend you speek with others with the same set up my boat runs out and I find it works better ,as for your prop depth your x demension is high that is for better top end and keeping the drives tucked in lets you get up with much less effort.
Rich
WATCHUS
RICHARD CUNY is offline
Old 08-31-2010 | 08:25 PM
i read somewhere on here that 1 way is for more speed and the other is for better control...but dont remember which is which
Drock78 is offline
Old 08-31-2010 | 08:28 PM
Turning in gives you more speed but points the X center point of your boat closer in so you have less handling (especially when docking) turning out usually loses 1-4MPH or so but you pick up a ton of docking capabilities in my experiences.
FuelinAround is offline
Old 08-31-2010 | 08:58 PM
I was just having this discussion as well, if you compensate for lower transom lift on the props would that work better ?
laszlo01 is offline
Old 09-01-2010 | 11:23 AM
blue thunder's Avatar
Spinning in provides better bow lift on a straight vee. Less wet surface. But you have to drive it more to keep it balanced on the keel. Dock manners are bad spinning in. I tried spinning out this weekend and had a very hard time getting on plane versus spinning in. My drives are raised 2".
blue thunder is offline
Old 09-01-2010 | 11:51 AM
Originally Posted by blue thunder
Spinning in provides better bow lift on a straight vee. Less wet surface. But you have to drive it more to keep it balanced on the keel. Dock manners are bad spinning in. I tried spinning out this weekend and had a very hard time getting on plane versus spinning out. My drives at raised 2".
To test, do you just change props from one side to the other?
1BIGJIM is offline
Old 09-01-2010 | 11:58 AM
If you have Bravo drives, thats all you have to do. Then run the shifters in reverse to go forward. If after testing, you want it to be permanent, just reverse the shift cable locations on the shifter.
Griff is offline
Old 09-01-2010 | 01:03 PM
Too Stroked's Avatar
I can't speak for all brands, but Fountain used to run them one way for their old "straight" hulls and the opposite way for the newer "stepped" hulls.
Too Stroked is offline
Old 09-01-2010 | 01:11 PM
I do have a harder time getting on plane turned out.... Takes full tabs and usually around 2500-3000 rpm to lay her down flat. But my boat needs bigger power and is extremely heavy.
