What causes my dip stick to pop out????
I am working the bugs out of a Paul Phaff engine swap in my Force Offshore. The engine still has a minor ignition issue and runs a little rough (cuts out and/or on/off at speed), so I will be replacing the thunderbolt distributor with an MSD setup. Other than that, everything is pretty sound, no backfires to speak of.
The problem I have is the dip stick will pop up about 3 or 4 inches after a full throttle run and mist oil everywhere. Is this a sign of bigger problems?? Or am I not venting the crankcase properly?? Any advice?? |
your getting some major blow by in the crankcase from the cylinder there. I had the same problem a few yrs ago with a turbocharged import i had (130,000 miles though). dipstick popping up and blowing oil all over the engine bay. within 6 months, i had half compression on two cyls. and you just had this rebuilt?
could be the venting ,what breather/PVC etc do ya have .
Mine would do it, I put a puke take on it with #12 lines and no more problems. I seen some engine builders put a spring to hold it ,band-aid it |
Nothing going to the air cleaner at this point. The valve covers both have breathers built in, I figured they were good enough to vent the engine. Where should I put a PVC on the engine?? There is no provision for one in the valve covers.
Originally Posted by xsboost525
(Post 3196074)
yes, doing a comp test will be sure to tell you alot and get you to a starting point on if you need to vent the crankcase differently or if your looking at a total rebuild. good luck man!
a leak down test would tell you alot more than a compression test sounds to me like the rings are not seated correctly or the vents are plugged up better breathers will probably take care of the problem
another thought ,to much oil maybe aerating it and building crack case pressure.Does it have a aftermarket oil pan /dip stick,are ya sure of the oil level?
What size/kind on breather ya got? if its blowing out the dip stick it should be blowing oil out the breathers also. ya don't have to have a PVC. do what Ebay Ed said ,do a leak down, that should show a indication of blow by. |
I agree on the leakdown test...tell for sure...50 hrs does not mean s#$t can blow one up in 2 or less...if the leakdown comes out ok a PCV will help..converted all my engines over to it like HP500 runs, keeps the engine cleaner..they run the valve in the intake base behind the carb..I used the valve covers on all of mine...
Ok, please educate me....what is and how do I do a leak down test?? I assume we are talking about a vacume test per cylinder??
Originally Posted by sixsixvette
(Post 3196264)
The test is done by filling the cylinder with a regulated air pressure then measuring the leakdown % past the rings , valves, head gasket ... piston must be @ top dead center on the compression stroke. |
Depending on the crank size, oil level, oil pan, and rpm, you could just be dealing with crank windage. Windage is oil getting aerated by the crank spinning at high rpms, it creates a vortex in the crankcase and makes pressure, usually just pushing out the dipstick. Good oil pans with windage trays will help prevent this, but wont solve it entirely depending on how much stroke you have.
My 598ci N/A has less than 20 hours on the rebuild and is leaking down virtually nothing, yet I still have to spring the dipstick to keep it from pushing out. And this is with a good oil pan with kick outs and a windage tray. It doesnt blow anything out the breathers, at all. I have 4 breathers on it, so I know it is getting enough ventilation. If your valve covers/air filter is staying clean and free of oil, then your blowby probably isnt the problem. My 598 was blowing out a quart of oil onto the valve covers every 2 hours of run time before the dropped valve and subsequent rebuild, and that was with 4 breathers with 6" extensions stuffed with stainless scotchbrite pads to catch the oil. Now THAT was blowby. |
I had the same problem. Mine was from the breathers in the valve covers. I used plastic inserts and tubes to air cleaner. No more issues.
Wow Phil, thats pumping oil.
90% of the time you can fix this with dual breathers with the little filters on them, but a vacuum pump is the best solution for 598. Engine must be awesome though... Uncle Dave |
Originally Posted by Uncle Dave
(Post 3196634)
90% of the time you can fix this with dual breathers with the little filters on them, but a vacuum pump is the best solution for 598. Engine must be awesome though... Uncle Dave Like i said, now I have no breather extensions and it doesnt blow out any oil at all. I have 4 of the filter breathers on the valve covers, and am certain that I could do with just two, one per side. Prior to the rebuild I was leaking down at 10-15%, the ring gaps were set up huge, anywhere from 35-45thousandths. Now we are leaking down at 2-4%, with ring gaps in the 22-23thousandths range. It doesnt even push much oil out of the dipstick without the spring on it, just a few drops an hour. With the dipstick spring it doesnt leak at all. Engine is pretty sick, sounds bad at 6000rpm. Still making in the mid 700hp range with the hyd lifters, dropped down from 800hp with solid lifters. i can live with giving up some hp based on the added reliability. |
What you are describing is what Im probably going to move my tunnel hull to next a 598 N/A BBC- simple effective.
It's probably a (roaring) kitten at mid 7 HP too. good low rpm stable idle id bet. Thats also something I can deal with if I have issues. I can actually FIX a BBC. Ive been pretty impressed by my ilmor 710 700hp out of a 505 and still idle well and never have a speck of soot on the transom is awesome. As it should be for what it cost. another downside of the technology based engine Is that I dont have the ability to do much of anything to it but change fluids plugs and filters. If it stops there isn't a whole lot I can do but check the basics. Uncle Dave |
Viagra or Cialis:party-smiley-004:
(Post 3196685)
It's probably a (roaring) kitten at mid 7 HP too. good low rpm stable idle id bet. Thats also something I can deal with if I have issues. I can actually FIX a BBC. Ive been pretty impressed by my ilmor 710 700hp out of a 505 and still idle well and never have a speck of soot on the transom is awesome. As it should be for what it cost. another downside of the technology based engine Is that I dont have the ability to do much of anything to it but change fluids plugs and filters. If it stops there isn't a whole lot I can do but check the basics. Uncle Dave It idles like a champ at 800rpm in neutral, 600rpm in gear. Throttle response is great, though it doesnt much like running below 3000rpm as it doesnt get all its timing until then. Nice 3500rpm cruise, and it really comes alive at 4500rpm. With the solid roller cam, I was spinning it to 6300-6400rpm with a labbed 32p Bravo 1. CMI sport tubes dry to the tips certainly help with the sound.:coolcowboy: |
