Am I propped wrong?? >
Old 09-06-2010 | 07:48 PM
rchevelle71's Avatar
Originally Posted by astar77350
Sorry for my ignorance but when you say cup, what are you referring too?
The blades are concave, like a bowl, some props have more cup than others.
rchevelle71 is offline
Old 09-06-2010 | 08:52 PM
Gotcha, that makes sense now, well I will keep u guys updated on my trials.
astar77350 is offline
Old 09-07-2010 | 11:04 AM
onesickpantera's Avatar
The brand is a mercury marine laser II. The number on the side is 48-16546 21p. Not sure of the diameter maybe these numbers will help.
As Rchevelle stated that is a smaller diameter prop. Look for a 21 Mirage Plus or similar.
onesickpantera is offline
Old 09-13-2010 | 06:39 PM
Difference between Mirage and Mirage Plus????
Biciboyz is offline
Old 09-13-2010 | 06:49 PM
Question
Originally Posted by Powerquest_Baby!!
Im guessing a 21P Mirage Plus too. Your operating range is 4600 to 5000 RPM with a mag motor. You will probably gain about 600 RPM with the 21P which should put you around 4700 and in your powerband.
--Right now your damaging your engine by running it at such a low RPM vs what it was designed to perform at. I would change props as soon as possible.
Very new to this boating stuff. How am I hurting the engine by running at lower RPM? I would think lower RPM is easier on the motor ...not harder. Enlighten me ...please.
Also ....what temp should this motor be running at? Right now it running at 140 /150 ...which I think is cool but my mechanic said leave it alone. Good or bad?
Biciboyz is offline
