What would make Carb overflow when hot? >
Old 09-20-2010 | 07:22 PM
Thunderstruck's Avatar
Of Course it could. I guess you did say in your first post that you had a 500 HP carb and not a carbed 500 HP.
See post #8 but look at vacuum at idle vs power valve opening vacuum.
Long time cult member.
Thunderstruck is offline
Old 09-20-2010 | 08:07 PM
I have a vacuum/boost gauge but Vic Jr doesnt have any vacuum ports so I have to drill and tap for one. Guess thats my next weekend project ..
HTRDLNCN is offline
Old 09-21-2010 | 06:15 AM
power valve would have no effect on gas leaking in thru tubes, has to be fuel level rising after shut down, either fuel pressure, needle/seats, floats, etc..power would leak thru baseplate....Rob
ezstriper is offline
Old 09-23-2010 | 02:54 PM
thanks Rob..
HTRDLNCN is offline
Old 09-23-2010 | 04:07 PM
RICHARD CUNY's Avatar
My 850s both had the black floats and the epoxy that holds the weights in came off and the nedel and seat got cloged this year put metal floats in I beleve it was a fuel problem.
Rich
WATCHUS
RICHARD CUNY is offline
Old 09-23-2010 | 04:27 PM
Rich,before rebuild we did pull some unexplained crap out of needle and seat which was weird considering fuel filter was clean.
HTRDLNCN is offline
