lifter problems >
lifter problems
lifter problems
Old 09-06-2010 | 12:19 PM
Unhappy lifter problems
have brand new 540 dart short blocks, used my 502 heads off merc 500hp, machine shop refreshed all heads, up graded springs, comp cam and hyro lifters, crane roller rockers. engines run sweet untill 2800rpm then all hell brakes loose, the lifters sound like they are going to jump out of both engines, back it down they quiet down, 60 lbs steady oil pressure both engines. have triple checked everything. will check it all over again if any one has any ideas
senza is offline
Old 09-06-2010 | 12:34 PM
is the geomitry right,are the springs correct for the cam.are the lifters adjusted properly,it sounds like something is out of wack.
mike tkach is offline
Old 09-06-2010 | 01:10 PM
everything from cam, lifters, springs was all supposed to be matched from the same place that built the engines, the only thing we used different was the 502 heads
senza is offline
Old 09-06-2010 | 05:54 PM
BUIZILLA's Avatar
instigator
.100 pushrod difference?
BUIZILLA is offline
