Holly EFI?
Is the holly efi setup any good? Has anyone used it before? Thanks in advance!
I have the Holley MPI kit. I has worked well for about 7 years. I lso made upgrades to the kit, AN lines, bigger 42lb injectors, wideband O2. It is expensive but it starts and runs great. It will take some time to figure out your tuning, it was a learning experence. Tune on the fly and adjust as needed.
Fixx
The new denominator set up is really nice,comes with everything needed,if you add a o2 bung the set your minimum and max parameters then the pcm takes over to make the necessary adjustments..
look into professional products powerjection III..vary simple kit to install and will support up to 700 hp.. http://www.professional-products.com/new.html |
i have one on a pretty narly 454 in a truck and have no problems with it all, we set up on a dyno to just load motor on the rollers and tuned accordyling. very nice running streetable running efi system.
4 Attachment(s)
I have used the Holley setup with the 2000 cfm throttle body, 50 lb injectors, etc a few dozen times and love it. I don't use Holleys electronics though. I buy the kit with everything except the ecm and harness. For that I use a Mefi 4 and custom built harness. I can't say anything about the Holley software other than it has no knock protection and the Mefi does. On top of that, the Mefi stuff can be serviced by any Merc shop with a scan tool and most already has an ecm to use.
Here are a few pics of some engines with the Holley setup. Give me a call if I can help you out. Eddie |
This is a projection 700 setup? Is this junk, don't know much about it?
NEVER MIND, JUST REALIZED IT WAS A 2 BR setup |
Why not use a Big Stuff 3, mefi4 is ok but doesnt use O2's and why only have merc be able to tune it. Even Fast sells a complete efi setup for up to 600 hp.
Originally Posted by CSCinc
(Post 3204585)
You can buy the whole thing from MSD. Jeff |
fixx
Originally Posted by hallj
(Post 3204629)
Mefi 4 is capable of supporting O2's
Originally Posted by mrfixxall
(Post 3204688)
MSD sold the rites to painless wireing..
Here's the MSD setup, http://www.camaroz28.com/forums/showthread.php?t=587377 Which I believe was bought from UMI racing a few years ago, http://www.umiracing.com/gallery/Images/Catalog.pdf Plug in your CAN bus dash/datalogger and you're ready to rock! Jeff |
