-   -   Impellers twice (https://www.offshoreonly.com/forums/general-q/238847-impellers-twice.html)
GoFastScott 09-11-2010 01:20 PM
Impellers twice
I had my impellers replaced by a Donzi dealer, now 14 hrs later one of them is bad again. Anyone have any ideas why I am having this problem? There are only 2 things I can think of- 1- it wasn't installed correctly when they did them a month ago, or 2- when they haul the boat out and flush it they are somehow not doing it correctly. Anybody have any other possibilities/suggestions? I have never had impellers last for less than 100 hours in the past, getting frustrating!
Expensive Date 09-11-2010 02:43 PM
I really can't see how you can put them in wrong its kinda simple.Unless they did not lube them.The flushing yeah real possibility
Smitty 09-11-2010 05:29 PM
2 things kill impellers---age or lack of water. Since they are new, there must be a point where they are not getting enough water.
larry da outlaw 09-11-2010 05:31 PM
thats a shame. thats why I dont trust anyone working on my boat...even as something simple as flushing the engines
Too Stroked 09-11-2010 07:25 PM
The number one fastest way to wipe out one of those bad boys is to "dry start" a motor. You'd be surprised how quick that takes one out. Maybe the guys flushing your motor ...
GoFastScott 09-11-2010 07:51 PM
you guys are right- turns out the guy flushing the motors the other day had the switches backwards, closing off the engine he was flushing, then the other one. The marina paid for them, but i am still very upset- the manager almost dropped a load when I told him it would probably cost $40-$50 k for 2 new 525's, dont want to get anyone in trouble but still........... I will be doing all the flushing myself from now on....
Expensive Date 09-11-2010 07:56 PM
Not trying to scare you but how long did he run them with no water?How hot did they get hope you did not crack a header...or worse.
goldeneyee 09-11-2010 08:12 PM
The impeller housing and/or end plate is worn or scored. No matter how many impellers you install it will tear them up....
Expensive Date 09-11-2010 08:20 PM
That too
Too Stroked 09-12-2010 07:45 AM
One would think that would be pretty obvious. Water going in, no water going out ...?
Seems like every time I see a marina try to save some money by hiring low wage help, you eventually get one of these.
Hope it all works out OK for you.
