1987 Baja 240 Sport with 454 Mag >
Old 09-13-2010 | 11:44 AM
Question 1987 Baja 240 Sport with 454 Mag
I have a 1987 Baja 240 Sport with 454 Mag in it with a Mirage 21 P prop on it. Couple of questions. What is the max RPM I should be getting on that engine? Right now at max I am getting 4000 on the RPM gauge. Is the 21 p proper the correct one? I have read that maybe 23 p is the one I need. Will the 23 p porp let me get that extra RPM out of the motor?
Biciboyz is offline
Old 09-13-2010 | 12:36 PM
More pitch will decrese rpm. 1" of pitch = 200rpms.
That would have been a 330hp engine in 1987. You want to spin it about 4800rpms and with a 21 Mirage, you should be able to get close to that. I suspect you have a tired engine or are not trimming it up enough.
Griff is offline
Old 09-13-2010 | 01:02 PM
maybe your tach is off
captain girt is offline
Old 09-13-2010 | 03:45 PM
I have an 88 baja 240 sport 454 mag. you should definately be in the range of 4800 rpms, and with that size prop you should, key word should, be exactly in that range. Read through some of the posts from my thread that I posted a few weeks ago, it might be helpful.
http://www.offshoreonly.com/forums/g...ped-wrong.html
astar77350 is offline
Old 09-13-2010 | 04:59 PM
blue thunder's Avatar
1987 would be an alpha drive. What gear ratio are you using? I believe a 1.3:1 was common because they were stronger and the alpha was on the edge with a BBC.
blue thunder is offline
Old 09-13-2010 | 06:41 PM
Question
Don't have a clue on that one?
Would that be marked outside on the drive any where?
Biciboyz is offline
Old 09-13-2010 | 06:45 PM
Question
Thanks ....
Went throught it. So where are you now ...what have you figured works and doesn't?
21 or 23?
3 or 4 blade? Thinking it is 3 blade
14 1/2 or 14 3/4 diameter?
Difference between Mirage and Mirage Plus?
Biciboyz is offline
Old 09-13-2010 | 07:19 PM
your rigth. 136drive and they use a19cleaver prop back then or try a 19 mirage
bajabob is offline
Old 09-13-2010 | 11:42 PM
My 1987 Donzi 22C has the 454/Alpha combo. I run a quicksilver 21P cleaver 3 blade turning 4600 at 63-65mph
Planetwarmer is offline
Old 09-14-2010 | 08:37 AM
Originally Posted by Biciboyz
Thanks ....
21 or 23?
Im in columbia sc, boat on Lake Murray. I'm still in a guessing game right now as to what set up I like. I do know that my 4 blade 23p is giving me the best fuel economy. I'm able to run 35 to 40 mph between 3000 and 3300 rpm. but as for top speed i was only able to get to about 53 or 54 at 4200 rpm. I ran the 21p laser II and wasn't pleased, but one thing that was good was that it really opened the engine up and i was able to cruise in the 4800rpm range for a short period, I think that helped because when i took the boat out this weekend with the 4 blade back on, i was able to get to about 4400 rpm and about 58mph. A friend of mine has a mirage 23p 3blade alluminum that I'm going to borrow, i will let you know how that goes, not sure how i feel about alluminum but we'll see. keep me up to date as to your findings as well.
