Recomendations on new steering >
Old 09-22-2010 | 05:51 AM
Sonic30ss's Avatar
Default Recomendations on new steering
Looking for recomendations on steering systems-
After the LI race my steering is wiped out!
Pump siezed, steel line blew out, power steering control valve broken and leaking...might as well go to external at this point.
Any suggestions on equipment vs. price vs. quality
Sonic30ss is offline
Old 09-22-2010 | 07:51 AM
i have latham on my fastech 292...idk how they compare to the competitors.
1MOSES1 is offline
Old 09-22-2010 | 07:10 PM
The best bang for the buck is the Mayfair from CP Performance. It is a really nice system, especially for the money.
I also frequently use IMCO. It is a very nice system. Although, it is a little more than the Mayfair.
IMCO use a new rear outdrive cap to attach the rams to the drive. Mayfair uses a modular SS wingplate. It rally boils down to preference. I don't really care for having to deal with the wingplate when removing the drive. The modular one that Mayfair has takes a lot of the hassle out. It is probably stronger to, not that strength is really an issue.
One thing I can say about the Mayfair system is that it is 100% complete. The IMCO system does not come with a reservior or the high pressure line from the pump to the filter. You just re-use the stock hose. Or, you could get some fittings and hose and make your own like I do. It's only about $30 worth of parts.
On twins, I use the IMCO Unimount. It is a triangle ram mount that holds both rams and oil tubes in the center of the transom. It is the cleanest setup out there. On single, I usually use the Mayfair.
Hope that gives you an idea. A dual ram, full hydraulic single engine system from Mayfair is approx. $3200-3300. The same IMCO system is approx. $3700-3800. These are rough prices off the top of my head. I am a dealer for both, so I can get you more accurate pricing if you would like. Good luck.
Eddie
Young Performance is offline
Old 09-22-2010 | 07:55 PM
onesickpantera's Avatar
http://www.xsperformancemarine.biz/page3.html
onesickpantera is offline
Old 09-22-2010 | 08:02 PM
Recently installed a full Mayfair system on my 28 Baja. Fairly easy to do (once you are comfortable with drilling a lot of holes in the transom) and system works very good.
Sport 280 is offline
Old 09-23-2010 | 07:52 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
We also offer steering systems from Latham, Imco, Zeiger & mayfair..
An external system is far superior to an old school internal system.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 09-23-2010 | 11:41 AM
Rage's Avatar
Eddie
Is that full hydraulic?
Rage is offline
Old 09-23-2010 | 02:50 PM
bcfountain's Avatar
Registered User
did you notice any diffrence in your trun radius?i mean did you lose any or did you gain ?
bcfountain is offline
Old 09-23-2010 | 03:12 PM
Yes it is.
Old 09-23-2010 | 07:33 PM
Turning radius increased, but with twins turn in tight space is easy with forward/reverse.
The increase in security is well worth the turning radius increase.
Full mayfair system was about 4k from CP Performance.
