What heads?
1998 HP500 carb blue motor, can i get aluminum heads with all the right valve springs and valves that will work properly as a package.
Will original carb an intake manifold work and does anything mount off the head i should be aware of that needs to be drilled and taped or relocated.
Is the preferred heads AFR and can i get 75-100HP out of these as a bolt on? Heard of 600HP,but not sure what else might of been done?
Will the Gil manifolds bolt up ok?, Other studs or bolts required? (stainless)
Would i be able to use pump gas?
IS THIS THE MOST RELIABLE POSSIBLE 5 MPH GAIN I COULD DO?
Lot of questions,but i know you guys have the answers !
Thanks, Guys for any help or suggestions.
Randy
Randy
100hp gain with a cam change and heads. I doubt you will gain more than 40hp without a cam change.
http://www.offshoreonly.com/classifi...o36174-en.html
For $4,000 i guess the up side is more reliable than blower,i'm sure some would debate that?
With blower you only need head gaskets and redo carb? but more HP,sound right?
nope your pistons wont work with blowers.cant tell how much the heads gave me cuz i did 540s .
Unless i'm all wet which is possible.
Blower engine reliability is determined by who built them, not just because it has a blower. My hopped up 525SC with 8# of boost had 500hrs on it and was still going strong.
You could make about 650hp with a 250 roots blower at 5# of boost and a 1050cfm carb. The pistons are fine to run with a blower.
Head gaskets should be upgraded. It will be fine on 92-93 octane fuel.
