battery left en boat >
Old 09-29-2010 | 01:36 PM
Ken N's Avatar
Arrow battery left en boat
Can batterys be left in for the winter?.
Ken N is offline
Old 09-29-2010 | 02:12 PM
Yep...but it depends on your winters and storage...I'm in Wisconsin and it gets pretty friggin' cold here and I used to take them out...but then I put a charger in the boat which monitors &" MAINTAINS" the batteries during storage...so they never loose their charge and anytime they start to fall short, the charger kicks in with a small maintenance charge. So now, i never take them out.
Caluw1 is offline
Old 09-29-2010 | 07:46 PM
I do the same thing with mine
firehawkcat is offline
Old 09-29-2010 | 09:10 PM
I have never taken my batteries out of any boat I have owned for winter storage. Never had a problem in the Spring. As long as you don't hav eany slow drains, they will be fine. You can also just disconnect the battery cables to prevent the slow draws. If they get real low on charge, they will freeze and then they are no good anymore.
Griff is offline
Old 09-30-2010 | 01:03 PM
+4, I leave them hooked up with trickle charger.
TexomaPowerboater is offline
Old 09-30-2010 | 01:55 PM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
Me too. Always used an automatic trickle charger.
Baja_342 is offline
Old 09-30-2010 | 09:26 PM
Might pull fuse on stereo no sense in running the clock to drain batts. Less work for trickle charger
Old 10-03-2010 | 11:19 PM
Rebel_Heart's Avatar
I pull my stereo battery out and keep a trickle charger on. I have always just disconnected the main 2 batteries and left in boat. If I don't have a built in charger in the boat, any brand that you would recommend to charge 2 batteries that I could just temporarily put in boat for the off season? Thanks.
Rebel_Heart is offline
