Hard Starting Problem >
Old 10-04-2010 | 10:44 PM
Default Fixx
Originally Posted by DirtyJohnson
The fuel pressure varies between 4-7 psi so I think that is good. Floats I need to re-check. The pumping of the throttle makes sense and was never described that way to me before. I know the erratic idle is normal and a case of too rich usually. My idle screws are all at 1/2 turn. I am going to redo my timing when I put my new bushing in that is only a 14 deg adv.
Wouldn't an idle of 1000 at first then calm down to its normal surge be an idicator of a vacuum leak? Just trying to figure out all the different idle rpms I am dealing with.
because of the blower surge you want to check fuel pressure @ a slightly higher rpm,rev it to 1200 rpm's and check it..you want a minimum of 7 psi. the surge is normal.. read this article about adjusting your carb's http://www.candsspecialties.com/tuning1.html
FIXX is offline
Old 10-05-2010 | 07:28 PM
Originally Posted by Griff
No, it shows that its a little leaner on a cold start and then richens up as it warms up.
You really shouldn't have more than about 100rpms or so of surge.
Also, make sure to check the float levels with the boat at the same angle/slope it sits while at rest in the water.
checking on water is my next todo.
I thought 7 psi was max? For some reason my varies even when cruising. Im ok with the surge part, just trying to get a good idle all the time with easy hot starts. I have seen that tuning site, what a pain on a holley though. I would have to remove the carb to adjust the sec. Why do others say not to do this? I guess if I take them off and adjust them a 1/4 turn I should be fine from there since it is at 1/2 now and the pri at 1 turn.
Thanks for the help guys!
DirtyJohnson is offline
Old 10-06-2010 | 12:45 AM
Default Fixx
your feeding 2 carbs so i would try to keep the fuel pressure at its max,,your needle and seats should handle up to 9 psi with no problem..
FIXX is offline
Old 10-06-2010 | 07:41 AM
Have you tried blowing the idle air bleeds out on the tops of the carbs? Remove the flame arrestors, and stick the little red tube from the can of carb clean in them and give them a blast. They can get plugged up real easy, especially if your valve cover vents are plumbed to the flame arrestor. The blowby residue gets in them and plugs them up. Give it a try.
MILD THUNDER is offline
Old 10-06-2010 | 08:30 AM
blue thunder's Avatar
When you remove the carbs to adjust the secondary throttle blades, reverse that screw so you can access it in the future without removing the carb.
Good advice from mild thunder there too.......
blue thunder is offline
