5-Bladed Prop? >
5-Bladed Prop?
5-Bladed Prop?
Old 11-26-2010 | 12:33 PM
Originally Posted by Rookie
Can't he just buy a used BravoIII lower and put that on????
Yes he could. But the problem with the tach or whatever problem the boat has is not solved with that.
A.O. Razor is offline
Old 11-26-2010 | 04:19 PM
I have a 21p M+ that I'm trying to get rid of! will let go for $200 plus the ride...
It got my 25OL up pretty well, but you may look at a 21 rev4! That prop threw my boat up at 3k rpms no tabs and walked right up at 2500 no tabs. Full fuel but just me. (454mag)
nailit is offline
Old 11-27-2010 | 02:23 PM
AIR TIME's Avatar
the rev 4 is a great prop for deep drives ,it sounds like you might have b1 with the 1.68 gears instead of 1.50 which gave less powered boats a better prop choice. the other gears are the 1.36 which is for higher hp boats. tach sounds off, I had a merc 502 390hp at the prop and would turn it 4800 with a ol 24. see if theres a gear # on the side of the drive and have the tach checked your slip should be between 12 to 15% . good luck
AIR TIME is offline
