Repower project questions
I blew up one of my new engines with around 350 hours on it, and found out it was a rebuild when we tore it apart to inspect it. Obviously I'm a little gunshy and not-so-trusting now that I found out this guy in Rockville, Maryland sold me rebuilds as new.
I have to assume the other is a rebuild as well, so I'm selling it because I want two brand new engines, start fresh. Planning to keep the intake, carb, valve covers, exhaust and bolt on accessories for the new engines.
1. Not sure what I can get for the good engine, so that would be one question I have. It runs like a watch, doesn't have a lot of scaling because we boat in brackish water. The only reason I blew up the other is because a $150 Holley Marine Fuel pump crapped out on me and leaned it out while running 3500rpm. It finally broke loose a few weeks later.
2. I'm in the market for two engines now, 450 to 500 horsepower, able to run on 89 octane, reliable and dependable. I don't run WOT, usually 3500 RPM all day. 502's seem to be hard to find in stock, and prices are all over the map from $5k to $7k. Merlin 509's might be a good option, looking for some first hand experience and thoughts from you guys.
3. Why are 502's so hard to find right now, is GM retooling or something?
Thanks in advance.
Thanks in advance.
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
K2
If you use the right parts a rebuild is better that any crate motor. I prefer to pick and choose the internal components. Use a forged crank, rods, pistons, roller cam (from RMbuilder) and you are good to go. What do you have now?
All I have are the 2 existing engines, the one is perfect, runs great with no problems. The other is just completely shot, but I think I can still use the heads from both. We can't find the CAM numbers anywhere, so not sure what brand or grind they used. It had KB pistons in it. Not sure about the other parts and what I might be able to reuse just yet. Planning to pull and scope the good engine soon.
K2
K2
They're 502ci, 450HP's. The cast iron heads are probably reusable but I've decided to start with new, and since I'm going with a closed cooling system, the possibility of using aluminum heads enters the equation.
K2
K2
Exactly what does "new" mean to you?????
Even brand new stuff needs machining. Use what you've got and have it rebuilt by a reputable builder.
It will as good or better than "new"
If you want brand new everything, then you better get ready for a 30k price tag.
