Thermostat Housing >
Thermostat Housing
Thermostat Housing
Old 10-07-2010 | 08:40 AM
eightsecmopar's Avatar
Default Thermostat Housing
I want to put the circulating pumps back on my engines and was wondering what t - stat housings will work the best? Are the stock Merc ones still available? BBC with Gil exhaust.
eightsecmopar is offline
Old 10-07-2010 | 08:58 AM
Default fixx
if you only have 2 hoses going to the manifolds and none going to the riser then this woul be the one i would use and have used..
http://www.georgiawatersports.com/Pr...dcategory=2235
FIXX is offline
Old 10-07-2010 | 09:28 AM
What should the water pressure be at idle? My gauge is plumbed into the top of the intake not sure if that matters
Old 10-07-2010 | 10:25 AM
Default Fixx
i have no ides what your set up is and they all vary from boat to boat. but their is 2 npt threaded ports for your coolent temp and you couse the other for your water pressure gauge.
FIXX is offline
Old 10-07-2010 | 12:05 PM
Idle water psi is 0-5# on pretty much all boats. Idle water psi really doesn't matter.
Its the max psi you see at WOT that is important. 20-25psi is ideal for WOT.
Griff is offline
Old 10-07-2010 | 03:42 PM
If you want the above style thermostat housing, but in a stock merc version, I have an extra one laying around that is in really nice shape. It's not all chrome and shiny, but it's not corroded or anything.
- Will
wjb21ndtown is offline
