intakes
Old 10-16-2010 | 08:42 AM
Default intakes
will a 500hp intake work on a older 454 motor
rssteiny is offline
Old 10-16-2010 | 12:22 PM
Yes
Griff is offline
Old 10-17-2010 | 04:42 PM
blue thunder's Avatar
Yes as long at the older 454 has rect port heads. If oval port than no.
BT
blue thunder is offline
Old 10-17-2010 | 05:33 PM
You can put a rec port intake on a oval port head, you just won't see much of an improvement out of it.
The HP500 intake is a rec port, single plane, high HP intake. If you're going to put that intake on a 454 it should be a high rpm, high Hp application.
wjb21ndtown is offline
