HP Gains VS. RPM gains >
Old 10-23-2010 | 03:43 PM
Default HP Gains VS. RPM gains
Whats the rule of thumb when adding HP? For example, add 100HP per engine, same prop, how many RPM should one gain roughly??
MILD THUNDER is offline
Old 10-23-2010 | 04:01 PM
Ther are lots of variables, but on an average V-hull running 60 to 70 you should pick up four or five hundred RPM and six or seven mph.
oops, just noticed you said per engine. In that case double it.
HaxbySpeed is offline
Old 10-23-2010 | 04:57 PM
t500hps's Avatar
21 and 42 footers
I was going to guess.....and it is a guess, that your original info is correct. Editing your post to "double it" I think is wrong.
t500hps is offline
Old 10-23-2010 | 05:33 PM
No need to guess, it's actually fairly simple math. There are some variables, but adding 200hp to even a slowish v-hull running in the mid 60's will net you about 10mph or 700 RPM at 12% slip. A more efficient hull will see bigger gains..
pitch x rpm / (gear ratio x 1056) = Theoretical speed without slip.
Old 10-23-2010 | 05:43 PM
http://www.go-fast.com/boat_speed_predictions.htm
http://www.go-fast.com/Prop_Slip_Calculator.htm
Maybe you can figure out something using these.
Back4More is offline
Old 10-24-2010 | 12:49 PM
I added about 60hp to a 24 Outlaw and gained about 400rpms with the same prop. This was on a 60mph boat that went to about 65mph.
It is going to depend a lot on where you are starting. 60hp added to a 700hp engine in a 90 mph boat will not net the same results.
Griff is offline
Old 10-30-2010 | 04:04 PM
Correct. Lots of variables at play.
Post your current wide open throttle RPM, GPS Speed, prop pitch, and drive gear ratios. We can figure out your prop slip (aka efficiency) and guestimate what 100 more horsepower will push your boat. (or 100hp per engine if it's a twin)
AmericanMuscle is offline
