Blower Head Gaskets >
Blower Head Gaskets
Blower Head Gaskets
Old 11-05-2010 | 05:47 PM
Default Blower Head Gaskets
Have very well maintained HP500 has 200 hours ,at 150 hours heads were trued, all rebuilt,valve springs and retainers were changed etc.
Used Fel-pro 17048 head gaskets !
If i put a blower on with 5-6 psi ,do i need to change head gaskets again?
r015 is offline
Old 11-05-2010 | 06:02 PM
No, you will be fine. Just keep an eye on the water pressure. Don't let it get much above 25 psi. Cometics would be a better choice, but in your case the Fel Pro's will work just fine.
Eddie
Young Performance is offline
Old 11-05-2010 | 06:44 PM
Default Fixx
who's head bolts did you use?
FIXX is offline
Old 11-06-2010 | 01:25 AM
I used Felpro Marine head gaskets on my 525SC with almost 8# of boost and they were fine.
Griff is offline
Old 11-06-2010 | 08:37 AM
I really don't remember,but it was what Teague Marine suggested.I'll look into it more and make sure they are ok.
Thanks Guys
r015 is offline
Old 11-06-2010 | 11:04 AM
Default Fixx
Thanks Guys
like eddie said you should be fine,,as long as you have arp head bolts or studs..
FIXX is offline
