Copper in the Oil Analysis >
Old 11-11-2010 | 04:43 AM
Brass distributor gear?
Philm is offline
Old 11-11-2010 | 07:45 AM
Pretty sure the 496 is a distributorless ignition with coil on plug
4bus is offline
Old 11-11-2010 | 08:06 AM
Rage's Avatar
When I make hard runs I trim the drive out under load to gain bow lift at WOT. Could that be over loading the thrust bearing? The coupler is heavily lubed with the Merc specified lube.
Rage is offline
Old 11-11-2010 | 08:12 AM
Ted G's Avatar
No, but if there is too much grease in the coupler packed in at the front it can overload the thrust bearing.
www.cbpba.com
Ted G is offline
Old 11-11-2010 | 12:51 PM
Rage's Avatar
Yes mine is an EFI set up. Thanks for the thought though.
Rage is offline
Old 11-11-2010 | 03:18 PM
DesertRage's Avatar
Rage, Check to make sure your engine mounts are still tight. I have seen the 3/4" nut back off on the pedestal mounts. This would let the engine torque up and put pressure on the rear main thrust bearing. Just a thought... The ones I have seen were the port side.
DesertRage is offline
Old 11-11-2010 | 05:03 PM
Rage's Avatar
Hey Jon, thanks for the suggestion! I need all the help I can get.
Rage is offline
Old 11-12-2010 | 03:23 AM
valve spring shims....
mike11 is offline
Old 11-12-2010 | 08:06 AM
Rage's Avatar
Yes, I have the copper flash coated shims but they have hundreds of hours on them and the copper was mostly gone before this spike in copper in the oil occured. Thanks for the input.
Rage is offline
Old 11-12-2010 | 08:23 AM
Rage- Are you going to tear it down?
4bus is offline
