Header welding in Michigan?
I have a set of CMI E tops that have three leaks I need fixed. One in the head flange and 2 in the collector. I'm in Northern Michigan and am looking for someone good that can fix these right! Any suggestions? Anyone know if Valako does this?
send them to cmi,,if they leak then who to blame..
http://www.offshoreonly.com/forums/g...r-testing.html
Yes sir, I can weld them if they are cracked in the flange area or in the collector. If they leak in the primary tube you may have to send them to cmi to be cut and welded $$. I pressure check them before and after. JimV
