Exhuasting
Old 11-17-2010 | 04:07 PM
Default Exhuasting
I have stainless marine exhaust on my boat and i have a questionn. The chrome elbow comes off the manifold and up then the pipe runes straight out of the boat...my question is at the top of the pipe out the boat is a plug screwed into the top like a bung....What is it and why is it there and what can i do with it
Ntrsspray is offline
Old 11-17-2010 | 04:11 PM
Throttle Fever's Avatar
O2 Sensor bung?
Throttle Fever is offline
Old 11-18-2010 | 01:25 AM
A picture would be worth a 1000 words. Post one and somebody will be able to tell you. It depends on the size and location of the bunge as to what its for.
What can you do with it??? If its not broke, don't try and fix it, you might break something.
Griff is offline
Old 11-18-2010 | 02:28 PM
im not able to post pictures or else i woiuld
Old 11-18-2010 | 02:59 PM
Post it on flicker, photobucket, or a similar site and then post the link on here.
wjb21ndtown is offline
Old 11-18-2010 | 03:50 PM
Default Fixx
if it goes all the way through the inner and outer pipes its for a 02 sensor,if it just goes into the outer pipe then it for relieving pressure at the tip..you would pit a barbed 90* fitting in the hole and use a through transom fitting to plumb the water out of the boat..mainly for reversion purposes..
FIXX is offline
