Need to know the diff/?? >
Old 11-18-2010 | 12:29 PM
Originally Posted by Griff
If you use the 525EFI heads, then you will have to use 525EFI exhaust. They are a modified Edelbrock head with a different exhaust bolt mount pattern.
i have some merlin world product heads im going to use.
ridefast77 is offline
Old 11-18-2010 | 01:31 PM
Originally Posted by Young Performance
Not to be picky, but a tall deck (10.2") can accept up to a 4.750" stroke. I don't like going over 4.5" stroke since you end up with a very short rod and steep rod angle.
The Gen VI 502 has a stock bore of 4.468"
Eddie
Wow, I did not know you could use a 4.75" stroke. On a tall deck, when you use a 4.5" stroke do you use the offset pistons with standard rod length? Just curious..
jeffswav is offline
Old 11-18-2010 | 08:59 PM
With a 4.5" stroke, you can either use a 6.7 rod and a 1.25 compression height piston or you can use a 6.635 rod and a 1.27 piston. If you use a 4.625 or 4.75 stroke crank, you have to use a 6.535 rod.
You can get pistons with just about any comp. height that you can dream of.
Eddie
Young Performance is offline
