bravo assemblies..HD? HP? Standard??
OK, I thought I knew the difference, but maybe I dont..can someone pleassseeee explain the difference, and pics would be helpfull too..I know hp have the dimples in the bellhousing correct? Do the HDs? ......
stlliberator,
If you are talking about the transom assy.. the easiest way is to look for trim senders on the hinge pins. If they are there it is a standard. If they are not and you see SS hing pins bolted in from the outside. It is a HP gimbal and helmet.
I am not familar with HD? And not sure if some had dimples and some did not. It is for clearance of the upper pin ubolt, I believe.
stlliberator,
