XR Damage
#101
I ran an X drive with about 600 HP for 700 hours before I noticed a small amount of metal in the oil and could detect a high pitch noise that was new. Went back to my old B1 as a backup before anything came unglued. I did have some good power in front of it but on a fairly light hull in comparison to what some are running, Baja Force 235.
Back when I made the decision to go with an XZ vs an XR longevity was my concern. XR a little stonger but probably weaker when you have a lot of hours on it. XZ a little easier to break with high HP but hard to wear one out.
#102
Have to look in my laptop to be exact. I ran a stock 30 with the 600 on the 1.65 X Drive for at least another 350 hours. Until this year, I've averaged 300 - 400 hours per year run time.
Been through a lot. Drives, props, other parts. It honestly doesn't seem to matter to me regarding hours. Problem is, I'm at a power range where there really isn't a solid direction to go in unless you wanna put a surface drive on it.
Chit breaks. Bottom line.
Is your XR drive a 1.5 or 1.65?
#103
1.65 ratio is more of an "altitude" thing..
#104
#105
1.5 with a 27 Mirage Plus. Just took it easy on it and did not feed it much boost until up and on plane. I think one of the reasons it lived so long was my drive cooling. I have a Simrek (?) drive shower. When I had a supercharger I installed a crossover with a home made pressure relief setup that consisted of two valves, one blew off at 7 psi and the other around 14 or so. The discharge for these were T'eed into a 1" fitting that exited the hull above and center of the top cap. A HUGE amount of water is being discharge to the top cap a via the drive shower. The water would hit the top cap and splash back up against the underside of the swim platform and in general splash anything exposed back their. After hard runs you could not detect any real temp difference on the uppers vs cruising. That and 25 hour oil changes probably helped it along. I did break my XZ in with a 21 pitch prop for 10 hours then took it easy for an additional 10.
#106
What drive lube did you use?
#107
#108
Im just asking a question im doing a major upgrade in power and was wondering if i bought all the parts that are in this upper is it a good idea. I have a 35 outlaw with merc 525 with stage 2 whipples boat weighs about 9000 with fuel.
http://teaguecustommarine.com//store...roducts_id=936
#110
Same gears. The newer XR has addressed all the same characteristics of the Platinum Drive. Better top cap... They were not able to explain to me how it's any better than what I have. Perhaps I got the wrong guy; I don't know about that.
