XR Damage
#72
After the one Cryo set crapped out, I put one of the old sets that I took out back in....ran it for 2 more years.
I had to replace one of those gears due to part of the edge of the brass ring was peeling off, late last year.
Otherwise it looked good ( no pitting)...it was an older set, that pre-dates the junk they're putting out now.
So, I cant tell if they're lasting any longer or not.
#73
There was a lot of posting a while back regarding cryo treating the XR gears which alledgedly improved gear life/durability significantly. Micropolishing the gears was also involved at some point. Lower gear failure rather than upper gears was the focus. Does anyone know what is the latest is on that?
http://www.offshoreonly.com/forums/g...riment-21.html
I still have the treatment applied to customers gears on a custom special order basis for customers on a custom basis
#74
Articfriends (Smitty) had dialed in a process to significantly improve the life of the XR gears in high HP/Torque motor applications back in 2007. He was also looking into a CNC gear set of a higher grade steel in 2008 and then everything went silent. When I blew my gears this spring I PM'd him asking about availability of a set of his improved XR gears and no response. MrGadgets was aware of his work per his posts on Articfriends thread on this subject. Does anyone know why this all went silent? Did Merc buy out his work to maintain the status quo?
but what really happened was I was trying to get lower gears to last and looked into having custom sets built with the assistance of RM Builder/Bob Madera, we sent sets out and had the mettalurgy tested, dimensions copied, etc with the intentions of having some built, we found one supplier that had already built experimental sets for Max worx that lasted less time than stocks ones and we were at the point of spending 10,000 plus dollars on a few test/trial sets of lower billet gears but my phone quit ringing with guys that even wanted stock ones treated let alone custom built ones and a short run after the experimental sets were going to be done was still going to be 50,000 plus dollars with no guarantee that they would even last as long as stocks ones! At that point, the need for upper gears seemed to be the biggest problem I was hearing about and everyone that has looked into having them built found it was going to cost well into the six figures again with no guarantee thery would last or even work. The gears are near net forged, the only way to have a gear with any real strength made would be to have forging dies and a capable company do it . cnc'd gears wouldn't have the root strength being "cut" not forged due to the grain structure unless some really exotic material was used and even then it still a 250,000$ flip of the coin, I have spent enough money already experimenting to get where I am at so I am having lowers and uppers cryoed and polished but again, I have 2 sets of the early "good" xr gears in my drives. As far as aftermarket gears, I know for a fact there are aftermarket low qualit lower gears already out ther, the Chinese are using them in there 800$ lower bravo, there is no way they are buying 400$ lower gears to put in a 800$ drive, thing is, they don't offer them for sale and I don't think you would want Chinese gears anyways, Smitty
I was fortunate in this down turned economy to land a second job with a low six figure income, thing is I am still working 40 hours a week at my old job until I can retire and running my transmission/performance business with the help of my youngest son who I trained for 10 years so I am busy or gone 96 to 120 hours a week, doesn't leave much time for running/testing trial sets of gears anymore!!
#75
Smitty, Thanks for taking the time with your busy schedule to give an update. Sounds like we need your work here more than ever given the low quality XR upper gears Merc is now selling.
What of all that you learned trying to improve the life of your lower gears with ~1000hp do you think could be applied to improve the life of a current set of low quality XR upper gears at ~600 - 700 hp where they are now prematurely failing?
You mentioned that when you tried re hardening your lower gears to provide a thicker/deeper hardened surface" After 17 hours they were chipped up exactly the same as the oem's,only difference was the little craters were much deeper because surface hardness was thicker." Do you think that that might improve the life of the current XR uppers for the lower torque levels of a 600 - 700 hp engine along with cryo treating as well? Same question plus the addition of nitriding?
I guess a better question would be what would you do to best improve the wear life of the current low quality XR gears for a 600 - 700 hp application?
Thanks for any suggestions.
Bill
Bill
#76
Hello Smitty:
Did you ever try QPQ nitriding on the gear sets to see if it helps the surface wear and pitting of the XR gear sets or lower gear sets. It won't obviously make the gears internally stronger but we've seen very good results on items we have QPQ Nitrided for surface strength and ductability as well as surface lubricity and increased metal strength .003" to .010" into the material.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
#77
Hello Smitty:
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
#78
Hello Smitty:
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
As far as the new XR uppers, I hear that they crack and break with no rhyme or reason, the cryo iso will help keep them from galling but from everything I keep hearing they will probably break first, Smitty
#79
What of all that you learned trying to improve the life of your lower gears with ~1000hp do you think could be applied to improve the life of a current set of low quality XR upper gears at ~600 - 700 hp were they are now prematurely failing?
Bill
Bill
#80
In addition to using the Amsoil HD gear lube plus the Lucas oil additive and the cryo what would you do in addition to the current low quality XR gears to improve the wear life for a 600 - 700 hp application?
Bill
